メインコンテンツにスキップ
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197回答 すべてを表示
Where is the memory conroller heatsink located on early 2005 power mac
I have an early 2005 Powermac G5 dual processor 2.3 with 2GB of memory. I recently started this up and have been playing around using OSX 10.4.11. I downloaded a program that shows me the temps inside. I’m sitting idle. The temps seem kind of high. Both processors are around 53 to 57 C which might need the thremal paste redone. However, the concerning temp is the memory controller heatsink that’s reading 73 C.
If this is normal for this machine or if it might just need a dusting that’s one thing. But I don’t even know where this is located on the board. Any guidance is helpful. I plan on tearing this thing down soon and giving it a through cleaning, but if there’s any places I should focus on I will.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
So I will throw an answer here in case someone comes across this with a similar issue.
I should've wrote this when it was still fresh in my mind. However, the memory controller chip is on the back side of the logic board. YAY! You have to completely disassemble the Powermac and remove the logic board. I think there was either a separate fan for the memory controller, or one of the main case fans had a vent that went to the back.
The heatsink is held on by black plastic push pins that will break very easily. I don''t remember if I had modified new pushpins from Amazon, or if I had gone the nylon bolt route. If you get the push pins off of Amazon or a similar place, you have to use a razor to trim the wings to a similar size that Apple has in there and it should work. Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 72
