メインコンテンツにスキップ
Full Size Sedan sold to Police in North America as the Chevrolet Caprice Police Patrol Vehicle
3回答 すべてを表示
How to fix my rear bumper?
Hi All,
Just wondering how I can fix my rear bumper.. What kind of materials/tools do I need? Or is it better to replace the rear bumper entirely? If yes, is there an manual for how to do it? (just wondering if there are any hidden screws)
It’s a 2017 Chevrolet Camaro (not the Caprice, was unable to select the Camaro).
If a picture is required, please let me know.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Can you put pictures up please
さんによる
@barriphone Picture is attached!
さんによる
コメントを追加
1 件の回答
選択されたソリューション
It looks like something punched a slot in it and it's cracked on the top. I am not a body man but I have heard it being done with bondo and a flexible additive. I would would check into that. You don't need to replace the bumper. That would be expensive and you can either blend in the paint for those two areas or for a better result paint the entire bumper. It's hard to blend clear coat but if you do the whole number and it won't be noticed because of the seam between panels.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for your answer! Yeah it was already there and now it's the time I want to get it fixed :). Did some research and found something like this: https://www.walmart.com/ip/3M-Bondo-Stag...
Should that be enough? First I'll try to use the Bondo kit, otherwise I could paint it afterwards.
Thanks!
さんによる
コメントを追加
回答を追加する
koppie007 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 181
