メインコンテンツにスキップ
Table lamps are designed to sit on tables. They are not floor lamps, which sit on the floor. Table lamps are usually shorter than floor lamps.
Bedside LED Lamp turns on and then off in a blink
Hello everyone.
Here is my bedside lamp which has some problems, when I turn it on, it turns on just for a moment and then goes off. Which component in its circuit is probably causing this? Is it one of those 3 LEDs or that capacitor or one of those resistors?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Wow , the soldering looks bad.
Did you did anything?
Do you have a multimeter?
If so, since it has minimal components, you can actually test quick,
test the LED
Test the resistance of the resistor.
Looking at the LED, i doubt it is bad, it seems that there are bad solder in place.
I would suggest you to resolder those cold / bad solder joints first.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Erfan Monemi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 298
