メインコンテンツにスキップ
The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside the Model 1697 controller. This controller is similar to the Model 1697 with internal modifications. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for console use, but is PC compatible.
Elite Controller Series 2 (Not 1)  Battery Replacement
Microsoft’s latest ‘Elite’ Controller 2 (04/11/2019 UK release) has a built-in battery, is there a reliable teardown, where I can safely access the controller internals to replace the battery for future reference?
(I would’ve selected the correct device, however Elite 1 was the only option)
Thanks in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
ベストアンサー
so basically you take of the two rear hand grips, and unscrew the four screws which are torx T9 screwdriver bits, then you pull of the front casing then take the internals out of the rear casing, disconnect the battery from the port on the mother board, then you plug in your new battery put your internals back in the rear cover, put the front cover on screw it back together and put the hand grips back on and hey presto new battery this wont take any longer then 10 minutes to do and you’re welcome
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
where can you get a replacement battery ?
さんによる
Thanks for the replying to this
さんによる
Thanks for the reply Folks.
Where can we find the battery?, please link it and DM me.
さんによる
コメントを追加
最も参考になった回答
Hello there, yes you can replace the battery.
There is a good teardown video here which I used to repair mine: https://www.youtube.com/watch?v=aS9_t1FZ...
There is a battery compartment which is easily accessible once the controller is open. The compartment is just closed by T6 screws and the battery inside is replaceable.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
That’s perfect,
Thanks man!
さんによる
Where would I buy a replacement battery? I’ve had bad experiences with “built-in” batteries on Xbox controllers and I much prefer using AA batteries.
さんによる
That youtube video doesn't show anything about the battery
さんによる
@Cincidubs its best to get the xbox rechargeable slim charge kit
さんによる
@Cincidubs here it is elite series 2 replacement battery http://egamephone.com/index.php?rt=produ...
さんによる
コメントを追加
Where it sells xbox elite control 2 battery?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zhen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 39
今までの合計 26,408
