メインコンテンツにスキップ
The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
100回答 すべてを表示
call them they can hear ruffling or a bunch of noise
I have a Samsung j2 galaxy that was just purchased on April 15th of this year. I just called my friends but all of them says that sometimes when I call them they can hear ruffling or a bunch of noise sometime when I call them and my voice sounds very low. Please help me.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @daisybivins411 ,
Is the phone in a protective case?
If it is try removing it from the case and check if you can be heard any better when on a call.
The phone’s internal microphone is located on the bottom edge of the phone to the right of the charging port. Ensure that the voice inlet hole, which leads to the microphone is not being obstructed by anything. Do not stick a pin or probe in there to try and clear the hole if you think that it may be blocked, as you can damage the microphone. Try using a vacuum cleaner to suck out any obstruction that may be there.
If the problem is still there, try connecting a set of earphones with the microphone attachment and make or receive a call using it to check if you can be heard OK or use the phone in loudspeaker (aka hands free) mode and check.
If you can be heard OK then there may be a problem with the phone’s internal microphone. As it is newly purchased get it repaired or replaced under warranty.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lillmzraw さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 47
