メインコンテンツにスキップ
9月20日に発売された、Appleのメインストリームとなる2019年iPhoneモデルには、6.1インチLCDタッチスクリーン、デュアルカメラが搭載されており、6色から選べるカラーセレクションです。iPhone XRの継続モデル。
478回答 すべてを表示
Slightly bulging screen and clicking sound in corners of phone
I recently got a 3rd party repair of my iPhone screen after dropping it as well as a screen protector, however, I noticed that the bottom right of my phone is slightly elevated. If I push down on this corner it can flex slightly back into a more appropriate position. When I apply pressure to the top left and right of the screen it flexes slightly and makes a clicking noise.
Here are the measurements of the four corners of my phone I made with a caliper:
Top left (clicking): 8.62mm
Top right (clicking): 8.67mm
Bottom left (no problems): 8.56mm
Bottom right (bulging): 9.06mm
(These measurements are all with a screen protector)
This has been bothering me recently because of the slight difference in the bottom right corner raises it beyond the barrier of my phone case and has been scratched and cracked because of this. What steps should I take to fix this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
If it bother you verry much then you can either glue the screen down to the frame or buy a new screen.
My choice would be a new screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It sounds like the screen wasn't put down completely and snapped into place. You could try to snap it down but I wouldn't recommend doing that. If you push to hard you can damage the screen. I would return the phone to the repair shop and show them your issues and ask them to fix it. Most repair shops would be happy to take care of any issues you have. They want you to be happy with their service. And don't do anything except return to the repair shop that did the repairs. You shouldn't have to pay more a repair you just paid to have done and shouldn't have to buy a new screen. And definitely DON'T glue anything on it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jonathan Kacines さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 36
今までの合計 1,530
