メインコンテンツにスキップ
このモデルは2016年に発売されました。2013年に発売されたCUH-ZCT1に変わる後継機です。コントローラーは前モデルと類似しています。
267回答 すべてを表示
My ps4 controller is all the way dead
I was playing my game and then my controller just blinks white for about 3 minutes and shuts off. This happened to me 2 times but after those two times the controller would turn back on after a while. But this time it didn't even if i put the usb in. I pressed the reset button on the back of the controller, i tried doing the “press the share button and ps button simultaneously”, the %#*@ thing wouldn’t turn on or anything even if i pressed the ps button on it. But strangely the controller would work only if it was in safe mode. Please if someone could help that would be very appreciative.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Could be a dying battery or power issue on the motherboard by the sounds of it
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Ok, thank you very much. Had a feeling about the battery and i played games while charging it, and would be overcharging for like more than it should. Ive already ordered a new controller and will send the broken one to a shop after this pandemic. Thank you very much i was close to losing it lol.
さんによる
@Jaws Glad I could help out! trying to isolate the problem without a spare battery to test whether it is the battery or not is a bit of a pain haha. I ran into this daily while trying to fix PS4 power issues controllers
さんによる
コメントを追加
It’s most likely I bad battery, on Ifixit you can purchase a battery for $7. They have guide as well to help you do it. Won’t take long at all.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jaws さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 16
今までの合計 678
