メインコンテンツにスキップ
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
Changed Ram and HDD = Dead Aspire One ZG5
Hello,
I just replaced the ram with Lexar 1Gb DDR 800/667/533, and 250Gb HDD. The netbook will not turn on at all, thought Ram was issue so put back old Ram, made sure followed all iFixit guide, again will NOT turn on.
Tried the Bios flash recovery steps but confused to file names and version I should use, either way the info I got, the netbook still didn't come on at all, no indicators lights.
I am super frustrated with this, I had this for about three years, worked fine tried to upgrade a little, killed it.
Please help if any, would be nice.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
If you tried to flash the unit and did not complete it successfully you may bricked your motherboard. For the record Crucial says the memory for your netbook should be PC5300--the memory you used was PC6400. At this point I would suggest you remove both the main battery and the cmos battery and leave them out for at least an hour. You can reinstall and try to boot again. I wish you good luck but if this does not work you may need a motherboard. Look on ebay for a duplicate netbook with a bad LCD. I am including a link to the correct memory.
http://www.crucial.com/upgrade/compatibl...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Eric さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,980
