メインコンテンツにスキップ
The Canon Rebel T6i is a popular, semi-professional grade Camera designed for any user. This guide is meant to aid in the repair of a few common problems that may occur during normal use.
25回答 すべてを表示
My EOS T6i camera will not turn on
Hello. I don’t post often on forums but this camera is really getting to me. I have had this camera for a while, just pulled it out of storage and bought a battery for it. I charged the battery and plugged it in and the camera wouldn’t turn on. I turned to some other friends and they tried their batteries and the same thing happened. I tried seeing if it was the battery door that wouldn’t turn it on, I tried cleaning the connectors. Any help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@purpleprius double check the battery door as well as the SD card door. Both have a switch on it. Try to gently press on those doors, or the switch if you can identify those, while you try to turn your camera on. Try to reseat the lens since it can give you power issues as well. If all of this fails you most likely have an issue with the DC-DC board on your camera. Take a look at the motherboard and see if you find anything which looks “odd” Use this guide Canon EOS Rebel T6i Motherboard Replacement for that. Replace the RTC battery as well just to make sure it is not what causes this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Anthony さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 26
今までの合計 752
