メインコンテンツにスキップ
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
31回答 すべてを表示
Truck won’t turn over, makes no sound, Gears shift without brake pedal
I was moving my truck from one part of my yard to the other. As I put in park I heard a pop and then my truck died. It will not turn over but I can put it in the on position and listen to the radio. I am also able to shift gears without having the brake pedal pressed.
I have replaced the starter, ignition switch, ignition lock cylinder, and the neutral safety switch.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It died while you were driving it. Does it try to start/crank over? If it does did you check for fuel and spark? If it doesn't crank over, did you check if the engine will spin over? Take a breaker bar and the correct socket and put it on the center bolt inside the crankshaft pulley and see if the engine will spin over buy hand. Let me know what you find and we can go from there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
JGD04 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 58
