メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
iPhone 8 bad audio during phonecalls
Haven’t had an iPhone 8 with these symptoms. People can’t hear me clearly during phonecalls whether in handset or speakermode. Sounds like I am far away or voice is cut off so I sound like I’m stuttering. Using voice memo voice works perfectly. My colleague changed the charging dock and it was fine for a day and the problem returned.
Audio IC related problem or something deeper perhaps. Any advice would be appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Can Siri understand you? If she can and as you said voice memos work fine I would be leaning towards a parts problem. When I am faced with similar problems I would put the logic board into a known good housing and screen. If it acted the same you know you have a board problem. I have not uncounted an iPhone 8 that needed an audio IC repair but anything is possible.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
KWH さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 100
