メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
904回答 すべてを表示
Fresh battery lasts about 1 hour
I have used the iPod for a day. Listening to some songs, nothing excessive. I noticed how the battery indicator with the screen on has about 80% but the device was still working. Suddenly, when locking the screen, the battery indicator appears near 10%. A few moments later, when the Hold button was unlocked, the ipod turned off and the message "very low batt" appeared on the screen.
During the playback tests that I did, from the 5 hour to the 8:40 hour, the battery indicator on the screen already appeared at 5% but it continued to work (for about 3 more hours) when the battery was drained and recharged, I assumed that it could be calibrated to show its real capacity, but it seems that it was not so
This whole issue of battery and indicators is very rare. thats no way to calibrate this batteries. i used 3 different ipod batteries with the same results.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Do you have access to a Mac?
さんによる
Yes, i have a iMac
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@aaarchvz these models have issues with the battery connector on the logic board. The gas gauge is one of those connections. You do want to make sure that the battery connector is still properly connected to the logic board as well as that the sliding lock is fully engaged and makes proper contact. Be carefully even during an inspection; the connector is flimsy and easily breaks off.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks a lot! I don't know what else to do, I already did the test several times last night and today in the morning, disconnecting and connecting the battery and it doesn't seem to work, the battery continues to drop fast. How can I make sure I am making a connection correctly?
さんによる
@aaarchvz in your case try a different new battery. There is always a possibility that this is a bad battery
さんによる
I've tried with 3 different batteries buyed at 3 different places. maybe the ipod is broken?
さんによる
コメントを追加
回答を追加する
Ariel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 74
