メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
710回答 すべてを表示
Will not power on. Tried everything. HELP
iMac intel 27” EMC 2429 Mid 2011. Hadn’t started it in maybe a year, it had been plugged in the whole time. Went to start it…dead as a doornail. No sound, nothing on screen. Believe I’ve tried everything, including: hold button 10+ sec; unplug power cord from wall for a minute; held button for a minute; (yes..cord is good—even tried the cord from my NEWER iMAC…did continuity check on the cord, checked voltage in the cord end); power button feels like it’s working fine (tactile feedback). So…that was all the stuff on the “outside”. Then we cracked the case to check the LED’s. Power plugged in, LED 1 blank; hit power button no change (all blank). WHAT NOW? Help and thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
internal power supply is probably broken.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you for responding. Would a bad power supply be consistent with LED1 being NOT LIT (I.e. the light is out) when the computer is plugged in to known-good power? I thought LED1 was the indicator of power BEFORE it hits the power supply? Thanks for any clarity anyone can bring...I'm hesitant to spend $150 on a new power supply when I'm not sure it'll work...
さんによる
コメントを追加
回答を追加する
Robert Stoney さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 35
