メインコンテンツにスキップ
The 2018 version of the Samsung Galaxy A8+ smartphone released in January 2018.
25回答 すべてを表示
Will I have any issues when using NZ sims with australian phone
I have an unlocked mobile and read about “region locks" in samsung devices, will this region lock effect the use of new zealand sim cards with devices brought in australia. Im going on a trip soon so plz reply.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @theandroidkid ,
Searching online indicates that if the phone was already connected to a Australian network and had been used for making/receiving calls and has also been network unlocked then it should be OK to use in NZ with a NZ SIM card.
I would also suspect the Aust. / NZ would be regarded as being in the same “region”, given the regions are very big areas e.g. Asia, Europe, North America, Middle East etc.
Just make sure that the phone is compatible with the network that you want to connect to in NZ which no doubt it will be
Technology GSM / HSPA / LTE
2G bands GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 (dual-SIM model only)
3G bands HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 26, 28, 38, 40, 41, 66
Speed HSPA 42.2/5.76 Mbps, LTE-A (3CA) Cat11 600/75 Mbps
Have you seen this regarding travelling to NZ?
“Still current at:16 May 2020
Updated:14 May 2020
Latest update:If you're in New Zealand and want to leave we recommend you do so now while commercial options are available. Follow the Australian High Commission New Zealand on social media for regular updates. If you're an Australian normally resident in New Zealand you can return but you'll be required to isolate for 14 days in either quarantine or a managed isolation facility in your arrival city. This includes if you're travelling on a yacht or other small craft. If you're in New Zealand, minimise your risk of exposure to COVID-19. Follow the advice of local authorities and stay in touch with family and friends so they know you're safe and well.
Our level of advice has not changed:
Do not travel to New Zealand”
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bryn Trainor さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 7
今までの合計 539
