What is the typical success rate for Isopropyl Alcohol?
What is the typical success rate for Isopropyl Alcohol (91%) for water damage?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It would depend on whether or not the unit was powered up at the time water was applied to the iPod. If powered up and left that way (turned on--battery installed) for any length of time it probably won't help. On the other hand it doesn't hurt to try and you might get lucky.
このアンサーは役に立ちましたか?
I have used it for several years cleaning out boards and other electrical parts with no issues, i have not seen any water residue left behind. You can purchase pure alcohol at some grocery stores but it runs about 20 dollars for a 750ml bottle typically its about 94-99% Alcohol.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 940
