メインコンテンツにスキップ
Lenovo社によって製造されたラップトップモデルの修理ならびにサポートガイド。
2556回答 すべてを表示
Microfone not working in some apps (cisco webex, viber)
Hello, i have a problem with my microfone in my laptop, in my calls with skype they can hear me but not in viber and in Cisco webex meetings. The laptop is 6 months old and i have checked all the settings and the hardware is working properly.
Does anyone know how to guide me to fix it?
Thank you in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
You don’t really say what settings and where you checked.
Have you tried going in to the Control Panel > Recording > Select the microphone you use (is there more than one?) > Properties > “Device usage:” Is it set to “Use this device (enable) then in same menu > Advanced > Exclusive mode
Both
“Allow applications to take exclusive control of this device” and
“Give exclusive mode applications priority:
should have the check mark in the box.
Click O.K.
Fixed?
If not do the above with viber and in Cisco webex running and see what you get.
Long shot:
Some time unchecking, apply, OK closing and openning again and repeating with boxes checked fixes problem.
It would seem that viber and in Cisco webex are trying to use some other souund device.
Let us know how it goes.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Usually, audio problems are related to driver(s) needing update. But in your case since the Viber and Cisco webex meeting are the applications you are having problem with, then check if those applications have any updates/codecs available and contact their companies to see if they have addressed that problem before.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Child Universe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 390
