How to solve laptop hang issue?
I face difficulty due to laptop hanging while working from home. Provide me a solution to speed up my laptop.
Thanks in advance!!
この質問は役に立ちましたか?
Thanks in advance!!
この質問は役に立ちましたか?
Hangs have varied causes and symptoms, including software or hardware defects, such as an infinite loop or long-running uninterruptible computation, resource exhaustion (thrashing), under-performing hardware (throttling), external events such as a slow computer network, misconfiguration, and compatibility problems.
To solve the problem, check out posts and troubleshoot by yourself:
このアンサーは役に立ちましたか?
Thanks for your kind solutions, I will check out it. If you want to write an article about this problem we are happy to publish your blog on site: http://techidology.com/
@johnpeter07 Thank you very much, will let you know if there's any interest.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 419
1件のコメント
Hi John,
There are literally hundreds of possible causes.
We will try to answer your question if you give us more details.
We are not clairvoants!
Like what operating system are you using?
What program or programs are you using when it happens?
Is it overheating?
Etc., etc. etc.
Regards,
Mike
mike さんによる
