メインコンテンツにスキップ
The Dell Inspiron 15-7569 is a 15 inch laptop with touchscreen capabilities. It’s a 2-in-1 hybrid laptop/tablet released by Dell in 2015.
3回答 すべてを表示
My Touchpad Right Click is Getting Stuck When I Tilt The Laptop?
Is there anyway to fix this, I know I could probably clean underneath the trackpad but how in detail would I need to go to fix it myself, because I am strapped on cash because of everything that is going on. Thanks for the help in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Hi @dev0 ,
Here’s the service manual for the laptop, taken from this webpage.
Go to p.45 to view the necessary pre-requisite steps and then the procedure to remove/replace the touchpad. This should give good access to the buttons
If it cannot be fixed, search online for Dell 7569 touchpad button board - example only to get results for suppliers. The example was shown only to give you an idea of the cost of the part. There are other suppliers that may suit you better.
If you had a USB or BT mouse lying around, you could connect it to the laptop and use that instead as an alternative workaround
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just reinstall the touchpad driver and see if the problem is solved!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Devo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 26
今までの合計 1,229
