メインコンテンツにスキップ
Acer Aspire 3 A315-21-92FX is a series of with budget computers designed and sold by Acer. It is one of the cheapest computers in the market. The camera is equipped with 720 pixels HD webcam.
17回答 すべてを表示
Acer Aspire A315 Windows 10 Touchpad not working
Hi have updated Bios and Drivers, seems a Windows 10 issue, after reboot touchpad works until device boots into windows 10. The bios contains no touchpad setting to change from basic to advanced. Any ideas or pointers would be great.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
4 件のコメント
Hi
Have you checked the status of the touchpad in Device Manager?
Go to Device manager > Mice and other pointing devices > click on the >symbol to the left to expand the list and find the Touchpad entry in the list.
Right click on the entry and select properties > general to view the status of the device.
What does it show?
さんによる
its listed under human interface devices. HID-compliant touchpad, says its working properly, no errors in device manager
さんによる
in device manger touchpad ic not showing
さんによる
I did all you said. Uninstall the existing drivers including the optical mouse I am using but still no use.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Things to try:
I assume that you toggled the Fn+F7 keys and checked if it turns the touchpad on and off?
Try uninstalling the touchpad in Device Manager (right click > Uninstall) and then allowing Windows to "find" it and reinstall it on restart and see if it now works.
Have you got the Synaptics or the Elantech touchpad installed?
Try going to the touchpad manufacturer's website or search for "(insert touchpad make and model number) Win 10 drivers" and finding the drivers appropriate to your model touchpad (see Device Manager for make and model info) and see if they work any better.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Yes, I never realized there was a function key to turn it on and off. !!!! I deleated and loaded drivers, I switched to an optical mouse. I considered a warranty claim..
thank you Jayeff.
さんによる
コメントを追加
回答を追加する
stephen さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 32
今までの合計 12,142
