メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
Home Button Pairing Functionality
Hello guys,
I know the home button loses Touch ID if I swap the button, but will it still work as a home button?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
No it will not work. You will need to purchase a universal home button for the return function to work.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What do you mean by universal home button?
さんによる
@solsanchor If you just replace it with another home button from a different iPhone 8 it will not do anything it will just be cosmetic.
A universal home button will function the same as original except touch ID
• Press home button one time, back to home
• Press twice in succession, bring up the background running program
• Press home button for longer time, wake up Siri
• Press power button and home button at the same time, make screen capture
さんによる
コメントを追加
Yes, if you change the home button it will still work as a home button but will lose the touch i’d. Make sure to buy a home button that doesn't use wifi. They make a exact replacement that doesn't use wifi. I believe they are around 15 dollars or so but don't quote me on the price I haven't checked in a while. I just checked and You can buy one from ifixit for 25 dollars. It will fit a iPhone 7/7 plus 8/8 plus. That will take care of the problem and it will work normally. I know this works as I have replaced a few that were damaged.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sol TT さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 143
