R2 input when L2 trigger
When I push L2 up in ds4windows I see R2 input. Any ideas?
Did it do the same problem while playing in your game ? Is there a L2 input and a R2 input or only a L2 input ?
このアンサーは役に立ちましたか?
Hi!
Most of the time the input board/conductive input foil is failing, damaged or not seated as it should. I advise to open it, clean it (also the rubbers for the buttons) and try it again. If this ain’t working, you need to replace input board. It’s not that expensive, but sometimes it can give you a hard time to get it seated as it should. (Also clean the contacts of the input board..)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 79
