On/off button doesn't respond well
The on/off button is working but i do have to push it with care.
Most of the time it activates apple pay which can be useful sometimes…
Is there a quick fix or do you need to replace a lot of parts?
hello
it seems your power button create multiple pulses rather than a correct on contact. The part by-itself is not expensive (flash flex ) and the repair is not difficult if you are used to repair iPhones. But you will need to dismount the display, the mother board and the rear camera. If you never did this, then be very cautious or go to a repair shop
このアンサーは役に立ちましたか?
Hi philipe,
Thanks for your detailed response!
I’ll guess I’m going to order the piece.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 10
過去 30 日: 20
今までの合計 121
