メインコンテンツにスキップ
2016年3月に発売されたSamsungの機種です。モデル番号はSM-G930Vです。
425回答 すべてを表示
S7 screen showing black with 2 thin green lines that flash across top
So effectively, i got a screen replacement, the screen seemed to work, but the battery image froze after plugging in. i’m not sure if that’s because of a motherboard, firmware, or something else, but that’s what’s going on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
There could be a couple issues here, all of which can be tied back to the screen in some way. It could be something as simple as a loose display connector, a damaged screen connector or ribbon cable, or a defective screen. Open it back up and inspect the display connector on both the new screen and the motherboard for any damage. Also check the ribbon cable. If that looks good, reseat the display connector and you can power it on without having to put the whole phone back together, just make sure you at least have the wireless charging coil making contact with the board as they have a battery temperature sensor.
If none of those solutions fix your issue, it could be a defective display or could’ve been damaged during installation. I rarely see galaxy screens fail due to a defect after repair, unless you ordered from Amazon, eBay, Craigslist, Wish, or AliExpress. They have no quality control over products such as phone parts so anyone can sell any junk part they can get their hands on.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i think i toasted the whole phone. The red light isn’t even coming on anymore when i leave it to charge. The charger and cable are known good ones as well.
さんによる
コメントを追加
回答を追加する
Caleb Perkins さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 152
