メインコンテンツにスキップ
Are MBP A1150 and UMBP fans physically the same?
I have a A1150 MBP its old but does the job,
i replaced the screen with a 1680*1050 screen
but thew rest is stock
the mbp runs hot and the fans are half dead
they go to 3k rpm and make crunching noise (something is broken there)
anyway
i checked ebay and the fans look identical
physically
but i read the connector is different
it not a problem to re-solder the connector
so the question is, are they PHYSICALLY the same?
ie the distance between the screws and the WHL dimensions
thanks!
ps: i would just repalce them if i had a spare UMBP :)
also the price is about 10$ lower than the old fans
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Not a direct answer to you question, though a direct answer to your problem. Peel back the paper on your fans and put a drop or 2 of 3-N-! oil in the exposed hole. Reseat the paper covering and/or put a piece of tape over the fan bearing. I have repaired hundreds of noisy computer/laptop fans this way.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Cost Effective +
さんによる
コメントを追加
Just get the correct part. You're going to have the wrong connector and after soldering the old one on it may not work. Personally I put in new fans as the used ones on eBay usually already have a lot of use already.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
meim さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 3
今までの合計 572
