メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Why won't my phone turn on and the home button broke?
I was facetiming and my phone overheated so i hung up and then tried to text and it froze and went black. I then pressed the home button to try and turn it back on and then the home button “locked” i can’t press it down anymore and my phone won’t turn back on i tried doing a hard restart pressing power and volume down for 15 seconds but nothing…any suggestions??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
On the 7, the home button actually doesn't click - it's just a touchpad. The clicking feeling is actually simulated by the Taptic Engine. Crazy stuff!
さんによる
コメントを追加
2件の回答
The only other thing that might help is connecting the phone to a computer with iTunes, and trying to update it using Recovery Mode. See this article for tips on how to enter Recovery Mode: https://support.apple.com/en-us/HT201263. Be warned - clicking Restore will DELETE your DATA!
If this does not work, your phone will need to be opened up to be repaired. Follow iFixit’s iPhone 7 Logic Board Removal guide (iPhone 7 のロジックボードの交換), but you can stop unscrewing components after step 24. Instead, simply disconnect everything from the logic board but the power button cable, the display, and the battery. This will determine if a faulty camera/earpiece cable ( a fairly common problem for this generation of iPhone ) is causing your problem.
Best of Luck!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I know it's supposed to be Replacement instead of Removal, but I never have a spare logic board to Replace :)
さんによる
コメントを追加
It sounds like you need more help than a help forum. I think you need professional help and you could cause more damage if you try to do this without the knowledge of how to repair it. My recommendation would get an estimate of how much it would cost. I would check with jessa from ipad rehab or Jason from sts telecom. They have excellent references. The both have websites that you can contact them by email or phone. You can also check out their YouTube channels. I hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
shauna rogers さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 38
