メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
Screen replacement not working
Hi ….i have an iphone 6 plus A1522….the phone’s screen touch is not worked….so i decided to change the screen by myself (professional) ….i ordered a screen from an online shop….after the screen arrived i tried but its not working just the backlight with nothing showed up…and then i put my old screen and its worked ….so I thought the screen is faulty…..so I bought another screen from another online shop….but it also did the same…..i tried everything like restore , hard reset , etc. I also checked the lcd connector ……. Pls give me a solution to fix this issue ….pls
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I think you have two problems here.
1.       An iPhone 6 plus with no touch equals “touch disease” This will be a board problem not the screen. A search on iPhone 6 plus touch disease will give you more information.
2.       If your old screen works and the two replacement ones don’t I would check the touch and LCD screen FPC connectors they might be bent. When connecting the old screen the flexes probably lined up but with the new screens the wouldn’t have and the 6 plus can be difficult to connect if you haven’t had experience. The connectors can bend if you try to connect them when they are not lined up.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Vimal JR さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 15
今までの合計 127
