メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
I don't know how much battery is left
My phone’s battery is completely dead, as in it won’t turn on even when connected to power. I think there is still enough energy (more than 25%) left in the battery, so i’m scared to attempt the battery replacement. If I can’t turn my phone on is there a way to drain the remaining energy from the battery?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Have you tried other lighting cables first, just to check if it’s getting a charge at all? The battery will naturally drain, albeit very slowly.
Regarding changing the battery. Yes, not having a full charge is best, but you don’t have to have it fully drained when replacing it. Follow the steps and take your time. As long as you SLOWLY work the adhesive from under the battery, the battery comes right out with absolutely no force.
What I used to do is get a pair of needle nose tweezers and pinch the black tab at the end of the adhesive. Then pull a little of it from under the batter and twirl the tweezers. I’ll grip on a little better and give you more of a handle to work with.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lucy Hanacek さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 31
