メインコンテンツにスキップ
様々なボート用の修理ガイドならびにサポート。
How do I remove circuit board from housing
The ECU from new cat engine got the pins wet and needs new plugs. The circuit board is glued to the housing tho and I’m not sure how to remove it
Suggestions / tips are welcome
Update (05/09/2020)
all the info I have on unit
they are very new so no old ones around
I’ll have to try that.. cat wanting like 10k for one
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
WOW! Thats going to be interesting to fix. Even if you get the board out, you wont be able to fix this without the right parts and tools. Looks like some of the pins are corroded away. You can clean the plug with isopropyl, 99%. Use a tooth brush or small paint brush. This will clean up the area to see how bad the damage is. Do that and post updated photos.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
I have new plugs already problem is I can’t access back side of board to desolder old ones and install new ones :( hence wondering how to remove board
さんによる
Pins in the plus are formed as part of plug so they are not removable individuality
さんによる
@chewychunga Whats on the other side? Would the board be attached to anything in the back?
さんによる
@casp3rtech it’s a cast aluminum plate with some fins for heat and a tube running across (for fuel so I think there’s a temp sensor on inside) but no mounts or anything
さんによる
@chewychunga well if it was me in this situation, I would try everything to get it out since it's already bad, nothing worst can happen. Make sure there is nothing on the other side holding the board to the housing and use a heat gun on one edge and try to push a small flat flexible plastic under the board and see if it comes loose. If it does then just do that carefully around the whole board. Can even try some playing cards at first to get an idea of what's going on under the board. If you're lucky, the board might be held in place just in the edges. If you could get your hands on an old unit and just tear it apart and see how its bonded then you can know how to remove your board without any damages. Unless the manufacturer will tell you how to get it done?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Mat さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 27
今までの合計 912
