メインコンテンツにスキップ
The Maytag model LDE8604ACE is a gas dryer produced by Maytag.
16回答 すべてを表示
Why is my dryer dead
Hello,
Last night when I went to put my clothes in the dryer my light on the inside wasn't on. I closed the door and push the buttons to see if it would work and nothing happened. I unplugged the dryer and plugged it back in and nothing. I checked the breaker and it wasn't tripped. So I turned the breaker off for a few seconds then back on, still nothing. Can you please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi,
Check if the thermal fuse has operated. (part #10 - motor drive parts diagram)
If the fuse has blown it will have to be replaced.
Be aware that there is always a reason why a fuse may blow e.g. if the hi-limit thermostat is faulty and allows the dryer to get too hot then the thermal fuse will operate to prevent a fire from occurring. I’m not suggesting that there is a problem with the thermostat, just that the thermal fuse is the backstop in case anything goes wrong.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sweetbear18488 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 265
