メインコンテンツにスキップ
モデル番号はA1199で2、4もしくは8GB容量
nano is on but wheel function not working
My nano is fully charged and on but the wheel is not wroking. I press on menu or play and nothing happens. I tried to reset it by holding down the menu and select buttun but it did npot work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
First try restoring it on iTunes. but if that doesn't work, it's very probably it is bad hardware. Try replacing the clickwheel (and headphone jack/case assembly) but if that doesn't do it, it's a bad motherboard.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
screen unlock system rebooting and taking off the code.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Would you mind putting this into a complete sentence?
さんによる
コメントを追加
Repair on my screenlock chromatic code 2generation code.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Would you mind putting this into a complete sentence? Instead of starting a new answer please just comment under your first one.
さんによる
コメントを追加
I had my 2nd gen nano, which I locked up on me. I used to workout with it and think it was moisture that caused it to seize. I put it aside in my closet and didn't touch it for a year. I fired it up just recently and it works as good as new. If this happens to any of you I recommend trying to demoisturize it by buying some silica and putting it in a ziploc bag.
Good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
fran さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 6,163
