Cooling fan not working 92 Honda Civic
I have the same question, but I will give feedback on the answer. I have a 92 Civic, replaced a leaking radiator, fan was not working, so I replaced with a new fan same time I replaced the radiator. Fan is new, fuse is good, fan will not turn on. I don't have a multimeter, and wouldn't know how to use it if I did. What do you thing is the most obvious problem ? Thank You
この質問は役に立ちましたか?
5 件のコメント
Thanks to both of you. With your help I found and replaced the radiator fan switch. The fan is now working fine, you saved me hours of head scratching, I really appreciate it.
Thank you again!
europajames さんによる
You are very welcome and all the best to you. Drive safe and stay cool
oldturkey03 さんによる
I have a 1995 Honda Civic DX with a radiator fan motor that will not turn on. I have tested the fan motor [its runs], checked the relay switch and fuse under the hood [they were replaced], changed the temperature sensor and thermostat and still nothing. With fluids filled, car runs fine for about 25 miles or about 40 minutes before temp gauge starts to move up and down slowly. By then reservoir is low and needs more fluid. Is here another fuse some where to check?
Alex さんによる
My problem I have a broken wire on the plug that goes into the sensor o thermostat housing where can I buy that plug
Ronald Michalides さんによる
How many fans does a Honda ballade 1995 model have all in all?
Meluleki Ndlovu さんによる
