Why don't my tablet pull up any networks when it did a few days ago
Will not show any WiFi networks I tried everything standard but nothing worked. My son's tablet works fine
Hi @jasons76 ,
Can you "see" your home WiFi network, if you place the tablet nearly on top of the WiFi router?
If so, then there may be a problem with the WiFi antenna or antenna connection in the tablet. A broken or loose connection perhaps
Here’s the ifixit RCA RCT6773W22 Motherboard Replacement guide.
In the images at Step.6 & 7 in the guide, the antenna is clearly visible (grey cable at the top)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 24
