My washer is not draining
I have replaced the drain pump and the wire harness and the machine will not drain. It is the Bravos XL Maytag washer. Also checked for items stuck in drain or in tub and all clear. What else can you recommend? The board?
Drain Hose
First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Here’s how to replace it:
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 9
今までの合計 133
1件のコメント
Hi,
What is the full model number of the washer?
jayeff さんによる
