メインコンテンツにスキップ
Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
27回答 すべてを表示
Vacuum won't let me push or pull on carpet.
I was using my Navigator Lift-Away Pro on the carpet and it was working fine then the red light came on and I couldn’t move it. After cleaning I tried it again soon as I put it back on the carpet it did the same thing again it seems the brush stops spinning.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Because of such a malfunction, I damaged my carpet.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Perhaps I would be able to help you if you described how you damaged your carpet and what kind of carpet you had. I had a similar problem with a vacuum cleaner and a long-pile carpet. Part of the pile from the carpet would always be sucked into a vacuum cleaner. Because of this, I had a flat area on my carpet. I tried it myself but couldn't fix it, so I had to give the carpet to people from https://elegantcarpetrepairs.com.au/carp... who restored it quickly. In my case, it was because the carpet was too old and the vacuum cleaner was too powerful. It is worth considering this if your carpet is many years old.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The red light indicates the brush roller has stopped. Something is caught inside the roller brush. Turn off the vacuum. Remove the object and turn it back on. Green light should turn on. Remember, brush roller needs to be turned on when your vacuuming carpet. If not it will be hard to push.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
drosser333 さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 49
過去 30 日: 243
今までの合計 3,956
