メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
MacBook Pro not turning on?
Hello!
I have a MacBook Pro A1707
It’s a 15inch with touchbar I believe mid 2016-2017
I just replaced the battery and it won’t cut on at all.
I went out and bought a brand new charger and it still won’t cut on
No lights, no fans, nothing at all.
Ive already tried multiple things like Cntrl + Option + Shift, power button.
Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
8 件のコメント
Who's battery did you use and did you follow the iFixit guide?
さんによる
I used one off Amazon, I can get the name of it if you’d like. And yes I followed the guide
さんによる
Did you happen to find out what went wrong? I am having the same issue.
さんによる
@Misty I. - did you replace the battery yet? MacBook Pro 15" Touch Bar Late 2016 バッテリーの交換
さんによる
@Dan - yes, I did. It started to work after I waited for about an hour. I am not sure if it's because my motherboard was somehow drained or had a very low power as I worked on it. I spent several hours since I also replaced both speakers and struggled with the glue.
さんによる
3件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
If the issue began when you replaced the battery, then the problem may be the battery itself or damage that occurred while replacing it. Try reopening the MacBook and looking for physical damage.
The fact that the battery light doesn’t appear is a clue that the battery is the problem, though.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Shouldn’t it still turn on though without the battery if it’s plugged in?
Also it was having issues before I replaced the battery, that’s why I replaced it. I believe it said replace soon or something like that, and it wouldn’t charge and when I looked, one of the cells were swollen, then I replaced it
さんによる
@am0960 If it won't turn on with both a new battery and a new charging cord, the problem may be with a motherboard component. Hopefully the swollen battery didn't damage anything, but if it did, the main circuit board may need servicing.
さんによる
コメントを追加
Have you tried to open it up and look for signs of corrosion or anything? I had my computer sit for a while, and this was the culprit. Ended up taking it into the Apple store, they removed my hard drive, then I bought a SATA-USB cord to get what I had off it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, when I replaced the battery I had to unplug a lot of things and take everything apart. There was no corrosion.
さんによる
コメントを追加
回答を追加する
annelise mitchell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 28
今までの合計 1,773
