メインコンテンツにスキップ
The HP Pavilion TouchSmart 15 family is a series of 15.0-inch laptops that include features from both the HP Pavilion and HP TouchSmart families.
6回答 すべてを表示
One hinge is broken and the frame to the screen pops and wires are exp
Where can I get instructions on how to repair the cover to my HP pavilion touch screen. Dropped it on edge and broke or bent one hinge. Frame snaps apart, wires are exposed. It works as is, but for how long?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
We need photos of the damage, but knowing these it sounds like the LCD assembly broke rather then the palmrest. Very common with these due to the brittle plastic contracting and expanding.
Since there is no good way to glue the brass back in once it happens, you’ll need to replace the back LCD cover of the machine, which we need to model number of to check what the HP Spare# is. There are a few of these it’s only sold as an assembly (primarily the glass cover variant) but the ones with a normal LCD bezel tend to be available with the part available piecemeal and everything else can be reused.
If it’s an assembly only part, you’ll need to buy a good used one and transplant everything to the used part.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Fran Hewins さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 15
今までの合計 291
