メインコンテンツにスキップ
The Lenovo IdeaPad Z570, manufactured by Lenovo, is a laptop computer identified by its model number 1024.
3回答 すべてを表示
Lenovo Z580 - Illuminated blank screen upon startup. NO POST. NO BEEPS
Hello everyone!
My lenovo laptop had a windows 10 installed which was acting weird
(Couldnt use the OS, couldnt revert back etc)
To solve this i removed the hdd, disassembled an ext hdd and used the usb extension with the lenovo hdd to backup all my data on another laptop with acronis
Later i created a partition on the clean drive and flashed an img of windows 10 to fresh install it
But the lenovo laptop doesnt even POST now. There is an illuminated blank screen as soon as it is turned on irrespective of whether or not the hard is installed on the laptop
Also the laptops bios is corrupted and cant be changed
Same goes with the boot menu
Any suggestions?
Update (04/12/2020)
Tried all suggested steps explained above with unchanged results
But my question is how can the board suddenly fail in about a weeks time having done nothing to the laptop?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Have you tried taking RAM Modules one at a time and attempted to turn the PC on? Also, try removing the battery, press and hold the power button for 30 seconds to drain the capacitors on the board, and try the boot up process again. If you still have the issue, might be a defective board.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Morphero Inine さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 20
今までの合計 674
