メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
Boot Issues: MacBook Pro boots with dark grey screen and boot issues
Ok so I have a macbook pro early 2010 15” i5 620m I can get this to boot from an SSD or USB drive but it wont boot from a hard drive, I’ve replaced c9560 and can get to the desktop where graphics acceleration, sound, usb work, full keyboard fine everything as expected.
My issue is the dark grey boot screen I cant get it out of that mode and it wont respond to normal keyboard prompts like holding option for boot selection or cmr+r for recovery mode. I also cant install an OS after booting to USB it allows me to do the install but then wont boot from the hard drive or ssd. Drivedx shows a faulty interface cable with errors but after replacing the cable itself I still have these errors. PS the SSD install was done on another machine as I cant install on this one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
My first suspect is your hard drive I/R cable that was not designed for the speed of an SSD. Next check to see if the SSD is backward compatible to SATA II. Most SSDs are only SATA III.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
What you're saying doesnt make sense, the sata cable was designed for SSD apple shipped this laptop with them and my ssd is working at sata 2 it says so in negotiated link speed.
My issue is a hard drive wont run on this. I'm assuming its a bad capacitor/bga chip on the logic board but dont know where to look.
さんによる
コメントを追加
回答を追加する
MacBook medic さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 40
