Captive portal internet traffic blocked
I can only go to 2 different sights it says it has blocked traffic on the internet
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try this:
You have to get the captive portal page to display. Try these tricks first:
These are all temporary solutions and not the most convenient ones. You may want to raise a complaint to your ISP or if you are staying at a hotel you may want to bring it up to the management as this is an ISP issue.
And if you are using a VPN the only way to connect through a captive portal is to turn it off. Unless you are using Speedify bonding VPN.
このアンサーは役に立ちましたか?
My t-mobile Hotspot was turning on my captive portale. Took my computer to a computer doctor.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 1,696
1件のコメント
My captive portale somehow got turned on. I didn't know of this issue before, so I thought I could fix it by resetting my 11e chromebook, but it did not work and I don't know what to do. Any help?
Christina Low さんによる
