メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
Black screen at startup, chimes repeat every two seconds, nothing more
My iMac shows black screen at startup and repeatedly chimes (normal chime - not the diagnostic beeps) until I press the power key again to switch it off.
Have tried (with USB keyboard) resetting SMC, resetting PRAM/NVRAM, entering safe mode etc (as here https://www.howtogeek.com/189104/trouble...). No success. Still same problem.
Any thoughts?
Thank you
David
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@davidbaker, see Help with iMac reboot loop which goes over the same issue you’re experiencing. It’s most likely an issue with the GPU, as explained in the thread.
Hope this helps!
-Alex
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Thanks @alexrobinson. I appreciate that.
Just checked that post. If I read it correctly the feeling was that that machine was crashing/restarting as soon as it started to generate video. (A problem with the GPU as you say.)
With this machine it restarts even earlier. I can’t even get near safe mode or verbose mode etc. It just keeps on chiming with a black screen. Nothing on the keyboard makes a difference.
Am I right in assuming that it will basically need a new motherboard?
Best
David
さんによる
@davidbaker, my girlfriend had an iMac identical to yours and she had the same issue you're describing, no screen response whatsoever. Even though the guys in the thread I linked said they were able to get some video, it doesn't necessarily mean it's a different issue, it just might mean your iMac is further damaged. I've read that some of these iMacs have problems with thermal management and end up cooking their GPUs to death. However, maybe @mayer would like to chime in?
さんによる
@alexrobinson Thanks, will address this tomorrow when I'm fresh and mind is sharper.
さんによる
@davidbaker Did you find out the issue? I've got the same model 27" iMac 2010 with the exact same issue you describe. I'm guessing it's the GPU but would like to hear if you got anywhere with figuring out what was wrong. Do you have any update? Thanks
さんによる
@fourcandles Sorry for the delay in replying. Yes indeed. It turned out to be the video card. Was fixed for £100 and the iMac is now working fine. Hope that works for you too.
Thanks @alexrobinson too for your help on this.
David
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
David Baker さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 88
