メインコンテンツにスキップ
Do I Have A Sealed System Issue?
My 10 yo French door refrigerator won’t get colder than ~42 degrees in either the fridge or freezer. All of the onboard electronic diagnostic checks come out good, the coils under the unit are clean, both fans are running, and the condenser is running an warm (not hot). But, the evap coils are frozen on the top right 1/4 and clean and dry else-wear, and there appears to be dried green sludge inside the backside of the unit. (See pics). What are the odds this is a sealed system issue and I need a new unit?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
@ladytech One for you.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Drew, you are correct. You have some erosion that has leaked the refrigerant. You definitely have an issues in the sealed system. The frost pattern tells me it’s low on refrigerant.
The leak can be repaired. I charge a minimum of $350 to repair a leak in the sealed system. Some companies charge a lot more. The repairs must be done by a qualified refrigeration technician per the EPA guidelines.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Drew Hilton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 36
今までの合計 2,674
