iPhone 7 randomly restart / reboot every 20 minutes
NOT SOFTWARE PROBLEM
Which part needs replacement?
You need to get a new battery. You’re battery inside the iPhone cannot hold enough charge to keep your phone on for extended periods of time so I would get a new battery and it should fix your problem
このアンサーは役に立ちましたか?
All parts except motherboard are less than 1 month old. It is problem on motherboard and i am wondering which ic is in need of replacement.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 56
Given the age of the phone i would test it out as it could need a new battery. Test with a new battery or does it continue to do it even when on charge?
Jade Richards さんによる
@Jade Richards the phone has all parts new except motherboard. I meant, which ic on motherboard is in need of replacement - i newer got phone like this one.
Filip Georgievski さんによる
Battery is aaa+
I forgot to mention. But i used same batteries on 100+ phones and none had that problem. Battery health is currently 99%.
