メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
HDMI PIN 18 issue
Hello everyone,
I bought PS4 with faulty HDMI port to fix it, learn something and get some practise. I am now waiting for my new HDMI port, but I have noticed something on the bord. As I checked conductivity between PADs and points from the diagram, I found, that PIN 18 is not connected to the capacitor on the right side(18).
I have also noticed that the back side of the diode and capacitor(Yellow dots) are connected and both shorted to ground.( Front side of the diode and capacitor Is connected too, but not shorted to ground.) Is that right ? I dont have another board to compare with. And if yes, where does PIN 18 go? Could that be an Encoder IC fault?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
@marcinn ..please list which board you have for further diagnostics help
さんによる
Where can I get that? Theres SAB-001 on motherboard, Is that it?
さんによる
コメントを追加
8件の回答
最も参考になった回答
martin … for sab-001 follow this pinout.
https://www.youtube.com/watch?v=KTQ5JkaL...
skip to the end for the testing points. if it doesnt match, theres a fault. post back for further assistance.
このアンサーは役に立ちましたか?
スコア 1
10 件のコメント:
Yes, the PIN doesnt match the video
さんによる
youll want to remove the component that doesnt match and test out of circuit. if it tests good, place it back and continue. something is shorted. it could very well be the hdmi contoller. i would start there and recheck the pinouts.
さんによる
Okay, I am gonna try that, thank you
さんによる
@jostewcrew so I have desoldered the diode and capacitor and noticed, that I have 3 pins on the HDMI controller (firts 3 from the left side behind the HDMI filters) shorted together. Dont you know where they should connect ? And when I removed the components, the pin Now connect to the right place
さんによる
Sorry, not only First 3, also some that Are connected to HDMI filters are shorted with first 3 pins
さんによる
5件以上のコメントを表示
コメントを追加
Hi, I have the same problem, maybe someone could give us feedback about value of this cap and diode from working MB. For me its 1,5 Ohms from the left side of thie components.
Thank you!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
14 pin point root i want
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i need help!!!!!!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i need help!!!!!!!! andrew!!!!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
how to get sab-001 ps4 hdmi disgram motherboard!!!!!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Capacitor and the diode are both grounded (caps negative if polarized diodes non-striped side)
Capacitor is noise filter
Diode is a protection for polarity
Both are for local part of circuit
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey friend, do you happen to know which ceramic capacitor is the one next to the zener diode?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Martin Jančík さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 33
過去 30 日: 131
今までの合計 13,123
