How is a blank screen fixed
I have tried the two suggestions always given for this issue; using the home and sleep/wake buttoms simultaneously and restoring in iTunes. Neither fixes has worked. Any other suggestiomns would be welcome.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
nevermind the rice...just clean and dry the phone as the water/liquid damage guide suggests.iPhoneの水濡れ・水没ダメージからの復旧方法
このアンサーは役に立ちましたか?
Try holding the power & home buttons at the same time for 30 to 45 seconds.You should then see the apple logo and your phone will turn on.
このアンサーは役に立ちましたか?
Thanks Jimmy but I have previously tried that fix, and a restore neither has fixed the problem.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 3,210
5 件のコメント
Phone powers on just no display? Vibrate works etc?What happened before you got the black screen?
pollytintop さんによる
I think it is powering on, I have heard email alert and the chirp sound it makes when first taking a charge. It is not reconzed by Bluetooh or iTunes though, and the ringer on the phone does not sound.
As far as what preceed this well I think I may have caused the issue by shutting down the automatic screen shut off, I put it on never and didn’t go back and reinstate the auto shut down. The screen also exhibits a transulcent (whiteish) shadow on the upper right side of the screen on an otherwise blank (black screen).
Thanks for your intrest.
Joseph A Ceapa さんによる
have you tried plugging phone in to wall charger for 1 hour? sometimes when the battery is too flat it looks dead and itunes won't see the iphone
pollytintop さんによる
Yes I have tried charging it for an hour or more, no luck there. Do you know if the battery can die completely and not take a charge. Nonetheless it seems as if I am off to the Apple store in the morning, it is the only phone I have and its not comfortable not having a phone.
I have been retracing the past few days and I now suspect water damage, especially after I opend the case and found water droplets therein. I have decided to open it up and try the drying technique solutions found here, starting with placing it in a bag of rice.
