メインコンテンツにスキップ
PS3に同梱されているコントローラーの修理とサポート。 2008年半ばに発売された6軸リチウム電池式コントローラー(CECHZC2)は、修理が簡単です。
157回答 すべてを表示
Controller is not recognizing inputs on pc and ps3
I have recently open my old controllers and cleaned it because i thought it will fix the no inputs issue, well it is still broken and no inputs are recognized, got to my pc and look at controller properties and started to mash buttons and nothing is lighting up even the analog sticks arent recognized, how to fix it? I cant connect it to the ps3 because the ps button is not recognized too. The model is CECHZC2H A2
Update (04/09/2020)
Here is the board, it is a different one
Update (04/09/2020)
there are 2 ribbon cables, and i think there is one burnt line
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@supermememaker2 … sounds like either a shorted board or loose connector/ solder joint. i would follow this guide to get to the input board and look for any signs of damage. also, look for any damage to the connectors/leads while disassembling/reassembling. post back here if this doesnt help and we can try further diagnostics.
DualShock 3 入力ボードの交換
このアンサーは役に立ちましたか?
スコア 0
9 件のコメント:
But my controller is a different one, it has a smaller board.
さんによる
I actually have 3 controllers. 1 ok 2 bad ones. 2 bad ones are different and 1 ok is an old one and that held up good.
さんによる
ok.... what happens when you try to charge it? any lights? signs of life? what happens when you hook it up to a pc? any chime indicating recognition? any function?
さんによる
@jostewcrew when i charge it, it lights up, and pressing any buttons doesnt do anything
さんによる
on the pc it recognized it but no inputs, it only charges
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Macix26 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 26
今までの合計 943
