メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Trying to find part number for MacBook Pro 13-Inch Mid-2012 display?
Hello everyone,
This is my first post on here. I am a repair technician at Batteries Plus Bulbs and I wanted to start doing some more advanced projects to keep me busy during this crazy epidemic we are living in currently.
I am attempting to find the part number for a MacBook Pro 13-Inch 2.5 Mid-2012 lcd display. I am not looking for the APN, (like 661-5232 or 661-5558) but rather a different number for the display. I am not sure what is called but an example of this would be LTN133AT09 or Hsd190Men4 or M170En06.
The reason I need this is to attempt to buy a LCD controller board for the display, such as this one: https://www.aliexpress.com/item/40000391... but I would like to make sure it is compatible with my screen.
The whole goal of this project is to build a Playstation 2 into the body of this bulky Macbook Pro, and being able to do this without using the logicboard of the macbook will free up the space I need to fit the PS2 inside. Once I start this project I will post updates as well as a DIY tutorial for building my Xbox One and PS4 into one console, which is another project I will be attempting shortly.
If anyone can help me find this number I would be very grateful.
Thank you,
Justin N
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Apple used several different manufactures for the display. All list as the similar 661- Apple part numbers. You have to look on the back of the display to find the exact one. You can generally use that number to locate one on eBay.
I have also bought the controller boards on eBay (for converting iMacs).
You might do best to locate your board first and then search for the corresponding display you need that it works with.
How to build a display using a iMac
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you for the answer. I'll get behind the display soon and see what I can find.
Thanks,
Justin
さんによる
コメントを追加
回答を追加する
FiftyFixes さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 225
