メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Buick Lucerne is a full-size upscale sedan sold by Buick from 2006 to 2011.
Does anybody have a schematic 2007 Buick Lucerne CXS airbag system
The airbag light on my 2007 Buick Lucerne CXS stays on I have read that it could be The seatbelt restraint system switches , seatbelt switches ,Electronica control module has been activated but the airbag is not deployed As a result of a minor fender bender.and in this case it may need to be reprogrammed.I need an electrical schematic diagram for the airbag system in order to troubleshoot it. Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @vkieley ,
Here’s a link to the Buick Lucerne 2006-2011 Service Repair Manual + System Wiring Diagrams
Scroll down and click on SIR, (under the Restraints section) then click on the reCAPTCHA checkbox to view the file. There is a download option at the top right end of the document window so that you can download it to make it easier to use
When you have the document you’ll find the schematics on the 2nd and 3rd pages.
The document details the complete procedure for testing the system in the vehicle. It is very comprehensive.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I've got a 2008 Lucerne super I will sell your either needs a starter or fly wheel all I know is I bought it in August it broke down in December and it's been sitting ever since because no one I know wants to mess with a Northstar motor
さんによる
コメントを追加
Run a real diagnostic test on it. More then likely it’s a broken wire in the front behind the grille. Honestly you probably won’t or can’t tell it’s even broken. What I would do is just give it the ole tug test.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vincent kieley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 36
今までの合計 1,176
