メインコンテンツにスキップ
2018年3月に発売されたSamsungのGalaxy S9の修理ガイド。
137回答 すべてを表示
White circle lightning , doesn't charge, diagnostic steps
Hello,
I am trying to save a S9, my company doesen’t need it (no warranty).
If I plug the phone I get a white circle with lightning icon, nothing change after an hour.
Bought another battery, nothing changed.
The phone turns on by itself, if not plugged. Phone vibrates, Samsung Galaxy logo appears and nothing happens.
No signs of burned, missing or water damaged components.
I have laboratory power Supply, microscope, multi meter and experience with notebook repair.
Can you suggest me any diagnostic steps?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
7 件のコメント:
Can you post a picture of this white circle you're talking about? And where did you buy the battery from?
さんによる
Could be a few things wrong with the device but i would test all major battery/power areas first have you tried to wirelessly charge the device to see it was battery or maybe even charge port?
さんによる
https://i.imgur.com/eUkr01t.jpg
I have no wireless charger, the second battery was charged when it arrived.
I am going to buy "hot air station" and remove the shield. Have no idea yet what and how to measure.
さんによる
I am having the same problem with my Samsung also.
さんによる
What is the problem when my phone goes around in circles while charging
さんによる
2件以上のコメントを表示
コメントを追加
2件の回答
If the phone does not boot with a known good battery, it is likely a motherboard issue. If you’re experienced with microsoldering it may be worth the effort, otherwise I would invest in a new phone or send it off to a professional! Also, just to be sure, I would disconnect the power button cable and try booting it up. Sometimes a faulty cable will cause boot issues.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I held down power button and then pressed volume up button and phone came back to normal.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I just did the same thing and it worked.
さんによる
I held down power and up volume button, went into reboot mode then the white android with the yellow triangle was stuck in the middle of my screen with the words no command
さんによる
コメントを追加
回答を追加する
sibbirius さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 72
過去 30 日: 293
今までの合計 18,127
