メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
Touch Screen Behaving Weirdly
In a fit of anger, I pressed down on my iPhone 5c’s screen, probably harder than it was meant to handle. Afterward, the touch screen started behaving weirdly. It wouldn’t respond when I touched it. It began pressing in random places on the screen, sometimes opening an app or something. The keyboard would sometimes not work on some keys, and often press the entirely wrong ones (e.g. pressing L and typing a Z). Sometimes the issue goes a way temporarily and I am able to use it like normal. I have tried closing all apps, I have rebooted numerous times, and have done a couple hard reboots. None of these had any impact on the issue. I am certain this is a hardware issue. If anyone has any words of advice, that would be much appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Sounds like you’ll need a screen replacement. You most likely damaged the digitizer which is what senses your touch. When that get’s damaged, it can cause issues like the ones you’re experiencing.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I ordered a replacement screen on Amazon. Hope it goes well.
さんによる
Don't use screens from Amazon, eBay, Craigslist, or AliBaba. They're junk.
さんによる
It seemed to have mostly positive reviews. What's not good about the ones from Amazon?
さんによる
@s0me0ne most of the time they're junk and they don't come with a warranty.
さんによる
コメントを追加
I have had the same problem but with an iphone 6s what I did was I took out the battery and put it back in and then it worked just fine.Sorry if it doesn’t work for you :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
S0me0ne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 52
