メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Left ear stopped working. Dead driver
Hello
I have the hyperx cloud alpha, out of nowhere the left ear stopped working, i saw some guides over here said that it could be a faulty wire so i tried to investigate and found that the left speaker (driver) is dead (i tested the drivers with some voltage the right driver made some noise while the left one is completely dead)
My question is this thing fixable ? Anywhere to buy the driver or if i managed to get a broken cloud 2 can i fit its driver in the alpha?
Thanks for any help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@bahaa_ay you would have to actually take some physical measurement for the driver to see what might fit. I would try and scour places like ebay, craigslist and pawn shops to see if you can find a donor headset from where you could transplant the driver.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thanks for taking time to answer my question I found a cheap cloud 2 for about 20$ but the driver on the cloud 2 is 53mm while the alpha is 50mm
Do you think it might fit?
さんによる
Sorry but no. It will not fit the housing.
さんによる
ok thank you
さんによる
コメントを追加
回答を追加する
Bahaa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 27
今までの合計 1,445
